so here it is, over 2 months later.
After a couple of cleanings and just today replacement of air mixture screws (and o-rings of course) the bike starts up REALLY nice and idles pretty well.
One concern though is the pipes are discoloring differently. The pipes are powdercoated silver and the left pipe is turning brown looking at the lower bend. Not sure if maybe this is a flaw in the coating. Most pipes I've seen that discolor, do it most up by the head and around the first bend. So far no discoloration at heads.
I'm not worried about the color except as a possible indication of over-heating on that side.
But there's still lots to do! Still haven't done a valve and/or cam chain adjustment.
Before I swapped out the air mixture screws it was doing this thing where after applying throttle it wouldn't come back down to idle right away. It would hover at higher RPM. Now it comes right back down. Also switched the throttle cable and grip tho, so that may something to do with it.
Looks like I will be using the stock throttle housing for now, as I just can't spend any more $$, and the chopper one I'd bought won't work with stock XS cables.
So, now that I'm faced with using that throttle housing, I'm also thinking I'll try to make that starter button functional - and maybe kill switch, too.
Right now I have a big rubber momentary switch just kind of dangling below the coil and would have to figure out a place to put it, anyway. So I guess instead, I'll spend that energy trying to wire in the stock starter button, and save the other button for later.
It's getting REAL hot now already outside in my carport. I would just wait til November but dang tho! bike WANTS to run!!!!!! I can't believe how nice it sits there and idles now! and if I blip it, it comes back down to idle so nice.
Still need to maybe adjust the air mixture screws. I'm just not sure they are set equally. I know you're supposed to screw them in til they "seat lightly" and then turn out from there. But one persons' "seat lightly" may be another's "that's way too tight!"
anyway, just wanted to express my thrill at better running after swapping out those screws.
