Following the carb guide using a good spray can carb cleaner will get most of the crud out of the carbs. Compressed air sure speeds things up. On some of the tiny holes that may be plugged, I use a twist tie from a loaf of bread. Strip about 1/2 from one end. This leaves a fine soft wire. Use this wire to carefully probe the holes. This will get a hole through the blockage. This will let the carb cleaner get to more of the blockage.
I recommend you do it your self, you will learn a lot about the carbs.
If you can't get them clean enough then send them to your friend.
