colebrooker
XS650E US import
Looks good, I bet you are pleased. How did you get it that clean or is it painted?
Right about that Leo, and Retired Gentleman YOU ARE A GENIUS!!! I am humbled by your knowledge!
I switched the plug wires and GUESS WHAT it fired up like a champ! One small problem, the right side is not firing although there is spark to the plug, so I guess it is either not getting fuel or the timing is off..........here is the proof that it runs thought all be it on one cylinder.
"][/URL]
Now the question is 1) why is the right side not firing...and 2) what did I do backwards and how do i correct it! Thanks in advance as always!
OH, and Mr Retired Gentleman...THANK YOU, THANK YOU!!!!
Me. Retired Gentleman, SIR..........I am once again indebted to you. You are TWO FOR TWO!!
Even though I labeled the wires when I took 'er apart, I must have messed something up...I switched the wires as per your suggestion and all is good.......plug wires can now be connected to their proper sides.
The not so good news...right side is still not getting "hot"
The symptoms.......
Compression on both sides is about 150.........good I think
Spray starting fluid on the right side ( the one that is not getting hot ) and the RPM increases.
Hold a rag gently over the tight side carb ( creating a "choke situation) on the air intake side and the RPM increases and I THINK the plug fires.
If I grab a lot of throttle ( with the engine warm ) she dies. Happens with either a fast or slow advance of throttle.
I am still encouraged, as I THINK these things are just "adjustments". Your input and advice appreciated as usual!
