Cal Schilling
This forum is awesome! So much information. Sadly I am away from the bike and not working on it currently which is a problem because I thought I was making some progress there (tiny progress but progress)
Peanut, Paul is right about the TCI being in a box and all the info he gave. I also grounded everything that was attached to the frame during the most recent tests so everything is grounded 100% now.
Paul, I started thinking a faulty coil and as soon as I get back to the bike I was going to look into that side of it to test everything out. I buried my repair manual last time and couldn't figure out how to test it. Found it right before I left.
I looked over the connections and it looks like it is pin to pin for the TCI so it would be plug and play the only thing I see is I would have to run jumper wires between the two so that I don't damage the 6 pin connector.
I have checked the parts list on "shopyamaha" and the ignition setup is basically identical to the XS SH. The TCI is in the same plastic box which is held in with 2 bolts under the battery and behind the regulator. The box is not earthed (plastic) and the TCI has a black wire that goes to the harness earth wire via the TCI pin connector. Heating is minimal from the switching transistor since it is only ever switched fully on or off. The transistor has a small minimal heat sink without any fins. The plastic box essentially has no ventilation but does have two small holes facing down which I assume are for the release of water/vapour. I suspect the Zener diode mentioned is one of the small glass ones located on the PCB - they handle only a few milliamps and do not require heat sinks.
Perhaps the TCI is faulty or even the coil? We have a real puzzle here! If the TCI has a doublesided PCB then all the semiconductor components are available, unlike the XS SH single sided PCB.
Note Added: Are those 5K ohm resistor caps on the plugs. They are generally a must with electronic ignition (TCI) to prevent electrical interference to the control board.
Id be willing to let you borrow a TCI I have. However, it is for an '81, which is 6 pin. The '82 has a 7 pin, so a minor modification would be needed on your end. (Side stand safety switch)
