Norton7d
XS650 Junkie
1976, on points.
In an effort to determine I am not overcharging, how does one test the brown power wire going into the VR, or the green wire coming out with the engine running?
Wont the motor die if I open up the nearest connector?
Or do I check further away from the unit at where wires end?
I did check and my VR case / shell is grounded, which I also read could be a concern.
Thank you.
Thank you.
