Oil gland nut plan:
The proper size heli-coil kit is special order here at Napa for $105.00, so that takes it out of the picture, local machine shops are closed for the week, not that I am in a big hurry, and I am guessing it would probably be a $100.00 set up fee to walk in the door, so reading the threads about this, I went to Lowes and got a $1.99 brass plumbing fitting with a 1/2 " pipe tread on the outside and a hole inside that I can drill and tap to M14x1.50. Taps of that size are practically unavailable around here despite 1. living in the Cndn Motown and 2. country has been officially metric since the present prime minister's father was prime minister. But a special order at Fastenall will have it to me next week at $21.00, still spendy, but what can you do. I will tap the inside thread to fit the Yamaha nut, tap the case to accept the 1/2" pipe fitting, trim same to the correct length, thread my home made time-sert equivalent into casing with some lock tight and that should be the cure. I will try to document this as it occurs.
My thread jump: I thought the pictured 19" chrome front wheel was HD, got it on a rusty generic springer fork attached to a given up on chopper project, but did some research and see that HD has 5 bolt rotor mounts and this is 4 bolts. The bearings accept a Yamaha front axle just fine, the hub is not very beefy, but has bosses across it and a rib around the centre. Can any of you identify what it came from?
