phil1rowe4
I realised that there were no shortcuts when setting up the carbs, so I stripped them down, adjusted the floats levels, cleaned them thoroughly, balanced the throttle stops and cables and then using the dead cylinder technique (and colortune) got them idling nicely. I also found the ign timing slightly advanced so backed that off slightly. The bike is now running quite well on the standard 25 pilots with half a turn mix screw setting. I've bought a range of pilot and main jets so I can try more tuning later on.
I've continued on with some of the fiddly bits and got the rear brake cable fitted, clutch and gear levers working and some other brackets made. Fixed a small oil leak in the RHS camshaft cover. Not much left now except to finish the instruments and cabling.
The biggest challenge has been trying to get the tacho to work. I can get a weak signal by coiling some wire (tried several insulated and uninsulated) around the spark plug lead but only get a couple of LCD bars at best. I've tried resistors, sine wave to square wave converter circuits, rectified signal from PMA, all with no success. Without an oscilliscope and wave generator I cant determine a) what signal the tacho wants and b) what signal the coil is providing. I can see a pulsing 12V signal from the coil using a multimeter but no more detail.
It looks like this instrument panel is about to become a thousand small pieces against the wall and I'll have to go buy a better quality one. This also means new dash mount and some re-cabling so I'd rather get the current one working, if possible.
If anyone has any ideas, I'd appreciate them.
Cheers,
Phil
Cheers,
Phil
