Phil, after it's finished, and before it gets dirty or wrapped-up with a 'roo, take some calendar quality pics. Keep them in reserve for the next (hopefully) calendar. I need that hanging on my wall...
Hi,
I've fitted the hydraulic clutch with some good results so far, after one ride.
I made up a clutch rod extender to fit into the new slave cylinder to get the length right and have ordered some 8mm stainless rod to make up a new one piece push rod. I made the extender a bit longer than expected and trimmed it down until the slave cylinder fitted against the engine case.
The slave is I believe a 28mm cylinder and the lever is 13mm. The lever feel is firm but the action is smoother than a cable and you could probably get away with a 12mm master to make the feel a bit lighter.
I haven't measured the push rod throw yet but by observation it looks like about 3mm+-.
Here's the pics. Apologies for the fuzzy ones.
