Oh, I like those. At the very least, they will nicely center the pipes on the port and make for a strong, leak-free mount. I made some up for mine from the ends of old stock headpipes. There's a step machined into the port for the end of the stock pipe to fit into. Unfortunately, it doesn't stick in far enough to fill it. That leaves a "groove" in the port and that is said to be detrimental to flow. You can see it here in this cutaway pic of Mike's inserts ....
To better fill that step, I placed my insert in the head first, then the seal ring and pipe on top of it .....
Still, the part of my insert that stuck into the head wasn't enough to fill the step, so I made up some pipe filler rings .....
Here's the total "stack" as I have it fitted into the head, filler ring and insert first, then the gasket and pipe .....
I wish I had a lathe, then I may have just been able to thin the lip down on the insert so it stuck into the head more, and not had to fit a filler ring.
