BigBore Flattracker
Good work BigBoreSwede. I am really interested on how you get on with the sump spin-on filter kit as am thinking about getting one from Rudiger myself.
Is the hole on the side of the aluminium block closed off? I presume the oil drops down through the gap into the spin-on filter then gets pumped up through the centre block and the side hole (top right on pics?) so must be blocked off on side. Have I got this right or is the flow another way?
XS Rob. Since my english isn´t that good look for the "oil filter"-thread started by INXS, I think. There you have the specs.
"the hole on the side of the aluminium block" closed of".....if you mean the "plug" visible on the aluminum block that´s a magnet. The bypass valve is on the other side of the block.
