yamapag
I hve a 82-83 xs650 im looking at a stator can i use any year stator????
|If you are still using the TCI ignition you need a late stator, 1980 up so it has the mounts for the ignition pickups. Also the late stater typically comes with the right brush block to work with a late model "ground side" regulator. IF you aren't using the TCI ignition you could move your late brush holder onto an early (pre 80) stator. The wiring plugs are compatible.I hve a 82-83 xs650 im looking at a stator can i use any year stator????
the plug from the stator and brushes was cut on my motor. dose it mater what white wire goes to what white wire??????
