Just noticed how many posts you have. How many are attributed to this build.
Ummm......probably a few.
Cables have been more challenging than expected.
Yesterday on started on the cables. The first one on was the speedo cable, two minutes and done!
“Oh this is going to be easy!” Or so I thought. Then I went to install the tach cable. Ruh! Roh! My new cable has the wrong fitting on the end. You can see the original cable on the bottom here.
So I put that aside yesterday and started on my clutch cable. I routed it through the frame and WAY too short!
WTH?
So I just kinda loosely draped it and hooked it up, I just wanted to see how the clutch felt. In a word Horrible. I could hardly pull the lever, I couldn’t get the adjustment right, I started worrying that all my mixing and matching clutch components was coming back to haunt me.
Getting tired and cranky I decided , sometimes you gotta know when to fold em, and I threw a cover over the bike and headed inside.
That evening I had a couple of revelations, after looking at tach cables online for sale, I realized that there was nothing wrong with the cable. That threaded part was simply a connector stuck in that threaded cap. I heated it up and it came right out.
So, I figured out the tach cable and then turned my attention again to the clutch cable. You wouldn’t believe the amount of time I messed with that. It was one issue after another. I finally figured out the routing for the cable, it’s noticeably shorter than the cable on my ‘77 and has to be routed differently, more directly. It has less of a sweeping curve and consequently makes the pull harder. I had trouble with too much slack in the free play of the cable, trouble with getting the clutch to actuate properly, I just struggled with everything and it was confusing to me.
I had the cover on and off a dozen times, I had the worm apart numerous times, I kept adjusting and fiddling with it and it , and it very slowly became incrementally better. By the end of the day I had the clutch actuating properly, but the pull at the lever is STOUT. I’m not really certain why. The entire clutch unit is from a ‘75, it has new plates, springs, mounting screws, new freshly lubed cable, the worm mechanism has been cleaned and greased.
It works smoothly and seems to have the appropriate amount of travel, it just pulls hard. Maybe it’s the fact that the cable has tighter bends, maybe the cable isn’t as nice as my Motion Pro on my other bike, maybe the angled levers on my other bike help some. All I know is my ‘77 clutch pulls mutch easier, and it has the exact same springs, plates, and screws.
Still to come, decompression cable and two throttle cables. Hopefully they will go smoother.
—Bob
