oldschoolxs
red brush wire is under screw #2, not #1 like stock. You can also see it on the link peanut posted of the stator from mikes. The red wire jumps over screw #1 and is under screw #2. Green is under screw #3. brushes look identical to the pic you posted.
Pics of your stator with a close shot of the brushes will help. Remove the brushes and get shots of those too.
Here is a pic of what the stock brushes for the 70-79 stators. Your should look like these.
I also posted a pic of the stock 70-79 stator. In this pics the green wire is hooked under screw #3. The black wire is hooked under screw #1, the brush with the longer metal mounting strip hooks under screws #1, #2 and #4.
This brush is grounded to the stator frame by these three screws and back into the wiring harness on the black wire.
Your stator has a different colored brush wire. A red wire. Which screw does this red wire hook under?
