Geezerman35
- Messages
- 24
- Reaction score
- 0
- Points
- 1
I have an 83 XS650 in a Paugho frame. I have a classic old headlight that the speedometer in the housing looks cool but doesn't work.
Oh yeah, the oil problem.
I had gotten a mechanical tach from Mikes XS. The problem is that at extended highway speeds (55/65 MPH) oil seeps out of the tach insertion point and drips down on the right exhaust pipe which is wrapped with heat tape. When I stop, that oil will smoke from the saturated tape.
I wanted to install a washer or something to stop it up, but there is a fairly large slot at the top of the threaded mounting piece that a washer will not be the solution to covering.
I only have the cheap Yamaha manuel (Haynes) that does not go into any detail or show that a special seal might be available.
Any suggestionss will be appreciated.
Thanks
Clay
Thanks
Clay
