My front brake squeals like a pig!
I decided today to try and rectify the situation.
However I can never just leave well enough alone, and so begins.....
Front brake overhaul Part 1
First off I decided that I might as well install the new stainless front brake line that I had purchased a few weeks ago but never had time to install, so I disconnected the brake line and let it drain and then removed it entirely.
I then removed my caliper and took it to the bench to work on. Now I have already recently rebuilt the caliper, so all I want to address today is the squealing issue.
5Twins had told me about some brake pad retainers that are a discontinued item that had little rubber squares in them to deaden vibration , like these.
So I thought maybe I could make something myself. I have some self adhesive foam dots that I thought I'd try.
I only applied these to the front retainer, but when I tried them on the foam was too thick and wouldn't allow the brake pads to move freely. So off they came. Next up some synthetic brake grease.
I applied a small amount everywhere there was a metal to metal contact. I should say that prior to this I cleaned all components and also sprayed some brake cleaner on
the pads to make sure they were clean.
I then turned my attention to the master cylinder. The inside of the reservoir really looked pretty clean and I thought I could maybe get away with just cleaning it up a bit and blowing it out. This was naive of me, I really wasn't taking into account that this really is a rather complex component with a lot of parts you can't see. So I broke it down.
If you want the definitive thread on rebuilding master cylinders look no further than the one by LittleBill.
http://www.xs650.com/threads/master-cylinder-rebuilding.7862/
It's the best I've seen. So I'll just show you what I found. See...first impression is it's not so bad.
But look a little deeper,
Now the bore for the master cylinder is about the diameter and length of my pinkie finger.
There is a lot of corrosion and zero room to work in there. There are also two snap rings that have to be placed deep in that hole that are a pain in the keester to access. I am about at the point where I'm thinking a new master cylinder is the better option here. It's funny but my brakes were really working pretty well but I couldn't live with the thought that my master cylinder has probably not had any attention in 40 years. So that's where I'm at right now. I'm looking for a new master cylinder and I mean a NEW one.
Maybe by next weekend I'll have it and I can get it installed. Then I'll be able to do stoppies!
Until next time
Bob
