Ah man Bob. Hey, spare parts in the carb box is always a good thing!
I’ve been riding this old bike a lot lately and it was time for some maintenance. Yesterday after a long ride I drained the oil and cleaned the filters and refilled it with fresh oil. This is the first oil change since replacing my clutch a while back and I was curious to see what the oil looked like. Surprisingly clean, very little amount of metal flakes in the oil filter.
I was out riding again this morning and I noticed some drive line snatch when rolling off the throttle and back on so I figured the chain needed adjusting as well. When I got home I threw the bike up on the center stand and measured the chain slack, yup two inches of free play in the chain. I was going to just adjust it, but.....
I’m looking at the chain and thinking it was getting kinda grungy and here in Arizona we get this sandy gritty dirt that sticks to everything, it really needed to be cleaned, but that job is a pain. And then it hit me, this chain has a master link, so I just popped off the link and rolled the chain right off, and I think I might have hit on the best lazy mans cleaning technique ever.
I have this old gallon jug , half filled with dirty old kerosene that I use to clean really greasy parts. Well I just tied a thin piece of wire to one end of the chain and dropped the whole thing down inside, put the cap back on and gently shook it for about five minutes. Then went out under my tree, pulled it up and out and hung it from a branch. Wiped it off with a rag and rinsed it with a hose.
This is absolutely no scrubbing, straight out of the kerosene, and that chain was a grungy mess going in.
View attachment 117547 View attachment 117548
Then I just laid it out in the hot sun for a couple hours to dry out.
While it was drying I decided to pop the left cover off my motor and see how well my repairs were holding up.
I had bad oil leaks from both the crank seal behind the rotor and the clutch pushrod seal, and a loose drive sprocket and also a loose starter cover. The first time I worked in there you could not even see the motor it was so full of crud. So here’s what it looked like today, almost a year since I last had this cover off.
Really not bad at all. No oil leaks that I could see. Mostly just gunk that had been flung off the chain.
I also pulled my stator off to have a look in there. The brushes still have some life left in them, and there was some oil film, but no visible leak. If I had to guess it was probably from vapor condensing.
I got everything cleaned up and ready to go back together.
Put some fresh grease on the clutch push rod and reinstalled the cover. Then adjusted the clutch free play.
By now the drive chain was dry and so hot you couldn’t hold it in your bare hand. I wound it back around the sprockets, reinstalled the master link and set the free play. Then lastly sprayed fresh chain lube on the chain and it was Miller time!
It felt good to do a little maintenance on the old girl. She was feeling neglected.
...With the motor not running, I shifted the transmission into second gear, pulled the clutch in, and kicked the kick starter...
Hopefully you did not sustain any injury.
Ouch!
Don't blame yourself, Bob. That jack clearly has it out for the bike. Didn't it buck it off last year during your original overhaul?
Should have been:
With the motor not running, in neutral, pull the clutch in, and kick the kick starter until free...
I have always used the "Fred Flintstone"* clutch clearing method, in first gear.
I do it with all my vintage bikes, every time I pull them out to ride.
* Credit to Pete for naming the procedure.
Put in first gear, stand up, stradling the bike, pull the clutch in, and push/pull the bike back and forwards until it frees.Please explain the Fred Flinstone method. Lol
