My Yamaha XS650 Street tracker Build by olddude13
STREET TRACK! i will run two piaa eye ball lamps in number plate and led tail light. more to come (workin on new triple clamps) my buddy is making a custom seat
Just made rear caliper bracket for brembo made spacers for axle, need to finish stainless steel stay arm and mount master cylinder. also new 520 chain and front sprocket rear is borrowed.
More progress, made caliper bracket for brembo caliper still need to run router around edges chamfer/radius.
Mounted 520 front and rear sprockets got chain on and lined up. workin on stainless steel stay link and mounting master cylinder on stock brake pedal bracket on inside of frame.
Could you possibly tell me a little more about your shocks? or where I can get some info. You bike is coming along very nice, keep us posted with more pictures.
Thank you,
Bryan
Mounted rear master cylinder. Found easy way to connect to existing brake arm lever found on drum brake bikes see pictures.
Check out how i installed my rear master cylinder. connected to existing drum brake arm.
