Hi guys. I'd appreciate your advice, especially if you have connected the yellow tachometer signal pickup wire from an Acewell Speedo/Tach unit to a stock 1981-1983 ignition coil.
The manufacturer's instructions provide two options; 1) wrap the end of the yellow pickup wire around the spark plug wire 2-5 times, OR connect the wire directly to the ignition coil.
QUESTIONS
1) Do I connect the yellow wire to the positive or negative coil terminal?
2) How exactly would I connect the yellow wire to the + or - coil terminal? I do not know where either is located on the coil (please see drawing in next post).
3) the manufacturer provided a 1Mohm resistor to help smooth out the signal, how do I use that? Do I solder it to the yellow wire in-line? Does it matter which direction the resistor is oriented?
Note: I have the signal pickup wire connected now using the 2-5 wrap around method and the RPM readings are all over the place jumping around wildly at idle and on the road.
Also, the manufacturer diagram below references a CDI - for our purpose that should read TCI.
Thanks for your time to read this!
QUESTIONS
