Well, the build is moving along on my '74 restoration, but now the real fun starts. When I got the bike, the main harness had been cut back past the main junction, and all kinds of mess spliced in. Same deal in the headlight bucket- there were clamp-on tie ins, wires simply twisted together, many splices with both tape and wire nuts. Gauge harness had been cut up as well. Well, fug that. I got an uncut harness from a '75 from Ebay, assuming they would be pretty close, close enough for me to find and deal with any changes. I also got an uncut '74 gauge harness.
Well, I'm losing my mind trying to reconcile colors with the diagrams I've been able to find on the forum. It's possible the harnesses I got are not the years they were represented to be, or the diagrams are not quite accurate, or both. What I have done so far is go through the gauge harness and verify which wires go to which bulbs both with continuity checks and confirming by jumpering to light the bulbs. I've done the same to identify the wires coming from each handle bar switch(continuity checks only on the bar switches.) I've taken photos of each harness, and marked them up to show connector type, color, and best guess as to purpose.
I had hoped with uncut harnesses, it would be a basic matter of following the diagram and matching up leads based on color and connector, but it's not working out. I'd like to see if anyone can help me start with identifying the leads coming from the main harness, then verify if I got the switches properly identified, then maybe provide some guidance as to how the whole mess fits together. maybe this might end up in the tech section after I get the marked up pics properly ID'd. Thanks!
