txpowdercoater
- Messages
- 206
- Reaction score
- 2
- Points
- 16
I have mine wired through the neutral relay so it doesnt turn on the headlight until I put in gear. This way sucks massively.
I would rather use the same relay and have it wired with the "trigger" power coming off the armature or something like that.
Hoping to keep the headlight off until the engine runs and then the voltage should trigger the relay to turn on the headlight automatically, henceforth making the starting draw not so much and easy starts.
Question of the day: will this work?
the neutral switch sux if you like to sit at a light in neutral and its night time and it draws a lot of attention to you w/ headlight blinking on and off, even from the first to second shift it blinks quickly.
