Newest Winter project
chief01
Started this in Nov just haven't had time to post any pics. Just got all the parts back from powder coaters and starting assembly. Spend a lot of time making the seat, first time, didn't come out to bad. Found a guy, locally who will do the upholstery. Hope to have it done for spring.
Its a 77 that I picked up locally that was in need of some serious work. It had sat outside for a long time, but it ran. Always a good start. The tank is a Benelli I picked up from a guy in PA. It had never been used and was dent free.
Got her almost done. Just need a front brake line and Pete's Electronic advance and ignition.
Did you retain the frame loop and make the seat hump to fit over it?
I assume the earlier post is a typo and the tires are actually 100/90-19 and 110/90-18, correct?
The end result looks well worth the effort. Nice job!
Yep, typo. You are correct they are 100/90-19 and 110/90-18. Yes cut of the loop and I fabricated the seat myself. The only seats I could find had a hump that was way to high and didn't follow the lines of the tank. Just waiting on PAMCO's advance unit and should have it up and running. Thanks.
