Oh boy.........now what have I done?
Actually came out a lot easier than I thought it would. My biggest concern was getting the exhaust crossover tube apart so I had been liberally spraying the joint with PB Blaster every time I had it running for the last couple of weeks and it twisted apart easily.
Used retiredgentlemans idea of 2 pipes and 2 guys. Slick idea, worked great and easy on the back. If you ever happen to read this in the future RG, thank you, what a great idea. I know one man with a chain lift or hoist would also be easy, but my hat's off to anyone who can bear hug and wrestle this lump out of the frame. Easy work for two guys but for one you'd better have your Chiropractor on speed dial. Well, if you're an old fart like me with a bad back anyways.
It's obvious from the above pic that the push rod seal is leaking, so that's on the winter work list. Must have been getting progressively worse over the season. Checked my log and I was last in there on Aug 28th and didn't notice this, or didn't make note of it. There has never been any oil on the ground or garage floor on this side.
I am wondering if you guys can tell from the following pictures if the other seals are leaking.
It looks like oil behind and below the sprocket, or maybe just chain lube fling?
And oil behind the stator/rotor. Hard to say how fresh any of this is. Maybe just 40 years of accumulated crud?
Should I do these seals while it's on the bench this winter? Or, clean it up, monitor after reinstall, and do them if needed when the engines back in the bike?
Some valve pictures.
These first 2 were originally taken and posted in my thread on July 21st. when top end job diagnosis was given.
And taken today, after running with hotter plugs 2400 miles later.
Again, taken today.
Tach drive has been leaking all summer as well. Sure wish I had had the seal and o-ring to fix that when I had the right case off a couple of weeks ago. Would have been a lot easier. So that's also on the winter job list.
So, that's where we sit. Gonna do a bunch of cleaning before I get any tools out again to pop the top. But wanted to post these pics inside the left cover before I clean up in there.
Thanks again for any suggestions or advice guys.
