Rob, downloaded and studied your pics.
Please revisit this post:
http://www.xs650.com/threads/on-the-road-again-at-40-the-bike-that-is.49360/page-10#post-515147
In our old shop environment, those cylinders would warrant an instant bore job. Wouldn't even bother measuring. Going with crusinimage 2nd over set, you can ignore trying to save the old pistons and pins. But, you can use the unblemished outer parts of your old pins to evaluate the conrod small ends.
https://rover.ebay.com/rover/0/0/0?mpre=https://www.ebay.com/ulk/itm/131956383746
If you manage to get this kit (limited availability at this moment), you can use its wristpins to evaluate the conrods.
The crusinimage delivery is surprisingly fast. Can you arrange acquisition thru a nearby member?
Edit: IMPORTANT - I'm assuming that your cylinders are stock bore. Need to measure them to be sure that they haven't already been bored, otherwise may need to go to 1.0mm over...
Replace the front guide. Use the recommendations from the senior/guru members on your choice of gasket set.
Completely decoke/clean the head and valves, then closeup crisp/clear pics of head seats, valve faces, stems, end.
Lighting angles, reflections, oily surfaces always throw me off. After cleaning/degreasing, need good pics of the cam lobe surfaces, rocker pads, adjuster tips.
