First off; which filter did you pull? If you opened the side screen and got chunks that means your sump filter is torn, not unusual, most of them tear, but it needs to be repaired. Everything you see in the side screen has gone THROUGH the oil pump! Some thin strips can come off the edges of the the front guide and that's no big deal but if there is a lot of black plastic and some aluminum or you find the rubber guide liner laying in the sump, well the engines gotta come out for a new OEM front guide.
