Lluber
Noob
So about a month ago my rotor went bad. Replaced it with a custom rewind job.. Whilel I had the engine cover off I got antsy and swapped out my front brake MC, levers as well as my clutch perch. Im using controls off a 08-09 kawasaki ninja 250 (not sure if that info is pertinent) I painted my foot controls, engine cover and most of the other parts around the frame. Basically just trying to clean up what I can.
after I got the clutch lever re attached and engine cover on I realized that the clutch was is very loose at the lever. I didn't touch anything inside the cover. My spring looks good and everything felt fine before I swapped the clutch perch. Im not sure whats up. Do I need to replace the clutch cable with a shorter one due to the new perch? Learning a lot of this as I go so be gentle..
Thanks Guys.
Thanks Guys.
