However, they shorted us one long screw, lol. You need 5, they only gave us 4.
+1 - it is very important that the slider be able to....you know, ....slide.
...Am I forgetting one?
To "what" will your battery ground cable connect?
Dang PCKOPP - you do nice work!
My battery ground cable bolts to the frame cross member right behind the battery box.
Or did I not understand your question?
There's a lot of info out there on proper grounding, improved grounding, the "Big 3 upgrade", ...etc. I'm not familiar at all with the wiring on your later model, but assuming you're retaining the starter, a good grounding system would have a dedicated heavy ground cable going direct from the battery to a mount point on or near the starter casing. A secondary smaller wire would go to the frame.
