corkypromo
- Messages
- 15
- Reaction score
- 0
- Points
- 1
Hi all,
I have been working on some non-charging issues. My rotor tested bad so I just replaced it with a brand new one. Now the main fuse is blowing every time I turn the key on. I tested the source of the short by removing all other fuses and unplugging the voltage regulator. Everything is cool until I plug the voltage regulator back in. That is what is causing the main fuse to pop. Is it safe to say that the regulator is the problem?
The connection running to the stator isn't pretty. It has melted a bit. would a short there cause this?
Just trying to decide whether to buy mikesxs regulator/rectifier, or to tinker a bit more and replace the regulator with the radio shack option or the chrysler.
thoughts?
BTW - it is a '78 special with points.
thoughts?
