Gcraay
I have a 1975 xs650 that I'm looking to use for a custom build. I found one with motor and all for $150.00. Heck I was just looking for a frame. Anyway, It has a chunk out of the main casing directly above the sprocket. It is not one that will be under stress from oil pressure or kick starter or anything so I was looking to get it repaired. The chunk is about the size of a triangle cut quarter sandwich. Probably ham, but definitely not salami. In addition I do not have the part and feel that the guy I bought it from is surely not looking for it. So, can I fix it? also I will need to fab out a screw hole, cause one went with it. I see some crank cases on E-Bay, fairly cheap, but don't know if that is the way to go. Any suggestions. I will need to hire this out.
