ANLAF
XS650 Guru
I have the right side cover off and replaced the shifter-shaft assembly. I have noticed the star-shaped gear selector is out of alignment - in the Haynes manual the diagram shows one of the arms of the five-pointed star pointing to about three minute to the hour if it were on the face of a clock. My donor engine is just that, but on the engine I am working on the star points directly upwards to 12 o'clock.
You will see my video at
The shifter-shaft I just replaced had its splines smoothed out with the pressure of my boot trying to find neutral, then losing 1st, 2nd then 3rd. Now I've got in there the clutch plates are less than 2mm, so that can't have helped the shift gear (new ones on the way). The oil has no metal chunks but has tiny black shards of hard material.
Questions
1. is the star aligned in an acceptable range of adjustment?
2. if not, what is wrong, and how to I put it right?
By the way my bike is registered as an 81, but I think it is earlier than that - engine number 3L1-002207X - could this be an XS-SF (Eur) 78-79? and my bobber project - engine number FO-254157 - could this be an XS-2E or XS-2F, 77-78 or 78-79. My donor engine (which look in almost new condition beneath the dirt - engine number 447-300690.
Thank for any help you might give.
Anlaf
Questions
Anlaf
