Good morning Ladies and Gentlemen
Am working through a basic restoration of my '78 SE and have arrived at the brass bushing replacement part. Whipped the swing arm off only to find that the PO has already done the job - not surprising as there was little side movement in the arm, but I had to look. After several self-congratulatory high fives and a prayer for the continued good health of the previous owner, I adjourned to my deck with a cold beer and computer and searched this wonderful forum for details on this replacement, to make sure that everything was done right and that the arm would stay in place at the less than excessive speeds I expect to demand of my motorcycle.
After reading a number of expert opinions, I have developed a concern. My pivot tube does not extend beyond the end of my bushes - they sit flush.
XS Leo posted this response to an inquiry.
"The tube #2 has to be just a bit longer than the swing arm so the tube #2 gets locked into the frame and the swing arm and bushes pivot around the tube #2."
Leo, are you referring to the swing arm body itself or the swing arm with bushes in place? Does this mean that the bushes have not been pressed into the swing arm sufficiently? There does not appear to be a gap between the bush and the arm. Do I need to pull the whole thing apart and try again? Should I remove the pivot tube and attempt to press the bushings further in? Can I ride it as it is without making my wife a widow? Was I too hasty in being happy??
All advice sincerely appreciated
