Wow, Skull. I hadn't thought about it that way until you ground out those numbers.
Yes, it'll take quite a few turns to get the oil flowing.
Another way, is to look at the published oil volume, 1.3 liters/minute @ 1000 rpm.
That equals 1.3cc per revolution.
First, it fills the right side filter chamber, then the hollow passage in the top front of the right side cover, then the main front gallery. From there, a lot of it will drain into the main roller bearings and the passages on the left side of the engine, down into the transmission.
Your 100 revolutions estimate would produce 130cc's, which sounds about right, to fill all that up.
If the engine isn't turning over fast enough, I can see that oil simply draining through all those orifices, and never reaching up to the front oilpipe's connection.
Gefest: Keep kicking more...
