1. Dismiss Notice
    Dismiss Notice
Well hello to you all
Discussion in 'The Garage' started by Moodubs, Nov 12, 2019.
Tags:
  1. Thanks for allowing me to join, I've just bought a 1972 Yamaha XS2 from New York. It was last registered on the road in June 1982 and has covered 21000 miles. She's now in North Wales having some much needed tlc. Quite a few parts needed, a lot can be saved. Over the next few weeks I'll be stripping her methodically and attempting to un seize her, along with getting more work completed on the workshop and it's fitments and tooling. I'll be asking lots of questions too and hope you guys can help. Thanks Moodubs IMG_20191106_190818_066.jpg s-l1600 (9).jpg
    MaxPete, Scripto VU, Wulfbyte and 6 others like this.
  2. timbeck
    timbeck XS650 Junkie XS650.com Supporter
    Welcome aboard Moodubs---I believe you will find there is plenty of good advice here and very knowledgeable help.....not me but others. lol
    tim
  3. That's a bit of a project you have there but at least it's not all in a basket!
    Welcome aboard!
  4. YamadudeXS650C
    YamadudeXS650C Central New York XS650 XS650.com Supporter Top Contributor
    Welcome Moodubs,
    You certainly are someone who likes a challenge !
    That is quite a project.
    The Honda seat is a curiosity.
    You will find lots of info and assistance here.
    MaxPete, Wulfbyte and Moodubs like this.
  5. Ha ha why thank you, a challenge, you wanna see some of my other projects, I've scaled down by almost 50% on quantity to get them finished, always wanted an xs650, I think the Honda seat is a cover only as it's on the original base which is rotten. Just working out what's scrap and what's 're useable. Thanks
    MaxPete, Wulfbyte and YamadudeXS650C like this.
  6. GLJ
    GLJ Never go faster than your guardian angle can fly. Top Contributor
    Moodubs
    Welcome. Glad to see another XS2 here. You do have a project there. Time, money and patience and good results can be had. Can you post a better picture of your front brake. There should be 2 nuts there. One for the disk shaft and one for the axle.
    MaxPete, Moodubs and YamadudeXS650C like this.
  7. Un seizing an engine in situ.....
    If I was to do it again, I'd drain the oil and leave the drain plug(s) out, pull the spark plugs and pour the desired penetrating stuff into the combustion chamber above the pistons. Wait until the penetrating stuff starts showing that it's down in the crank and then use a socket and breaker bar on the rotor nut- stator side (don't use the Kickstarter) ...it could take days for penetration but that should remove the guesstimation of if its ready.
    MaxPete and Moodubs like this.
  8. fredintoon
    Hi nj,
    that works to turn the engine backwards but turning forward only loosens the nut.
    How about putting the bike on it's centrestand in high gear and trying to turn the rear wheel back and forward?
    And yeah, quite a project "But I've seen worse."
  9. kevski
    kevski XS650 Addict
    305
    269
    63
    kent uk
    Good luck with that one, your Ford Thames looks nice from here.
  10. Hi sure the image was a little blurred, heres some better ones , hope this helps 20191113_195622.jpg 20191113_195652.jpg
    MaxPete likes this.
  11. Hi and thanks, the Ford is the guy I bought the bike off before he delivered it, Im not allowed anymore toys for a while
    MaxPete likes this.
  12. Greyandridin
    Greyandridin Got nothing to do and all day to do it XS650.com Supporter Top Contributor
    Moodubs
    Welcome to the sight If you want help with your 650 you've come to the right site
    These guys are good and they don't mind helping a person out
    Check the classifieds once in a while you might find some parts or use the wanted section to try and find what you need
    I've got a few parts from the classified section that I may have never found anywhere else
    MaxPete, gggGary and Moodubs like this.
  13. pjc
    pjc XS650 Enthusiast
    Welcome Home Moodubs!
  14. GLJ
    You got something strange going on with your front wheel. See the difference? Be interesting when you pull the wheel of what you find.
    MaxPete, Wulfbyte, gggGary and 2 others like this.
  15. thanks for that bud ill take a look in the morning
  16. TwoManyXS1Bs
    MaxPete, Wulfbyte, GLJ and 3 others like this.
  17. motormike
    motormike XS650 Junkie XS650.com Supporter Top Contributor
    655
    1,607
    143
    Mpls
    Gad Zooks.. a tip of the cap for take'n this project on. The 72' Xs2.. is the best look'n year of the XS series. Most where the candy red and white.. a few, blue and white.
    Please provide photos on the engine issue… cam chain snap, ?, piston stuck from long term sitting ?
    PS: since you're across the pond and visit " jumble meets " (swap meets here).. if you come across any Blackburne engine bits… let me know.... rare as chicken lips around here... we'r use'n Buick big block valves on mine.. they fit except the length.
    MaxPete, Wulfbyte, Moodubs and 2 others like this.
  18. Hi Mike its seized from sitting since 1982 when it was last on the road in New York, whats Blackburne engine bits pls
    MaxPete and Rasputin like this.
  19. motormike
    655
    1,607
    143
    Mpls
    It's a 1929 500cc.... stuffed in a Motobecane (French) unit... common back in the day.. the brit's provided engines for many other makers….mostly bicycle manufactures try'n to convert to motorcycles.
    My machinist …. has went above and beyond... had to send the crank assembly to your side of the pond to be rebuilt because no one here can do that style of bearings and rod work. We found that a Pinto piston fits perfectly.... My " pilgrim " oil meter-pump unit is suspect.... haven't found a replacement yet... the machinist thinks he can get mine to work.
    This project is a bigger money pit then owning a boat …. :) Blackburn sleeve.jpg
    MaxPete likes this.
  20. kshansen
    kshansen XS650 Junkie Top Contributor
    907
    3,305
    243
    Too bad that bike and project didn't stay in NY I have a few bits that are left from the bike in my picture over to the left. Not sure if any would be of help but am afraid the cost to get them to you would be rather high!
    Actually taking a second look at your bike it does look a bit better that the one I have some bits left from.
Share This Page
