1. Dismiss Notice
    Dismiss Notice
Discussion in 'The Garage' started by I am Carbon, Nov 24, 2013.
Tags:
  1. Machine
    Machine Race the wind Top Contributor
    I have seen those for many years on aluminum Japanese dirt bike rims.
    And Standard XS Aluminum rims.
    Maybe they are mostly provided for Aluminum rims for a lock action or just to prevent damage to the aluminum spoke hole taper ?
    Are they there on steel wheels ? I have no idea :umm:
  2. Paul Sutton
    Paul Sutton Buckhorns on XV1000SE Top Contributor
    I had a slow leak along the rim of a tubeless bike tyre so removed the tyre and thoroughly cleaned the alloy wheel. Previously I have used dish washing liquid in water to assist with getting tyres on but it has been my experience that the rubber quickly dries and most of the solution runs off. This time I took a new approach. I prepared a soap paste by putting some non-perfumed soap through a cheese grater. I grated approximately one heaped tablespoon of soap and placed it in a pot with 1 cup of water and heated to the boil to dissolve. On cooling the soap solution formed a very thick paste which could be applied around the bead with a paint brush. Because it was thick it stuck to the tyre and did not dry out quickly. This soap paste made the job so easy by lubricating the tyre levers that the tyre just popping back on with minimal effort. I only wish I had tried this years ago.
  3. lakeview
    lakeview XS650 Guru XS650.com Supporter Top Contributor
    Good Bones '78 Goes Silver
    Trying on the " dark steel" metallic silver rattle can painted tins. Yamaha badges are across the border now, thank you Machine and MaxPete. Also have side cover stickers to apply.
    Repaired rear tail light and rear direction indicators, set up rear brake and installed new Motion Pro clutch cable. Filled the carbs and started it, clutch action almost perfect.
    It's going back in the corner now so I can check over the red '76 VYR bike.
  4. Mailman
    Dang Lakeview!
    You’re going to have to go get you another trailer load of old Yamahas to fix. You’ve just about worked yourself out of bikes! Your speed is impressive! :thumbsup:
  5. lakeview
    Thanks, but it is a mock up for now. Not sure if I like the monochrome effect; may well try to mask off some tasteful tank scallops after the VYR and try to add some green accents.
    Superjet, MaxPete, Wulfbyte and 3 others like this.
  6. MaxPete
    MaxPete Lucille, Betty & Demi - I suggest but THEY decide. XS650.com Supporter Top Contributor
    Lemme tell ya - that Lakeview is a hard worker!
    I dropped out to the country estate the other night (and I do mean night) and had a listen to those Sportster mufflers on that ‘78 and they sound absolutely great. They look superb as well - HD chrome is really well done and the fit is like a factory job.
    If you need mufflers for your XS650, you’d be hard pressed to find a nicer set than those stock HD Sportster mufflers. From what I have seen, they are widely available as take-offs at HD swap meets all over the place because the Harley crowd likes loud custom pipes and often seems to sell these off.
    Lakeview - has built yet another really nice bike that runs well and looks very pretty.
    Pete
  7. lakeview
    Thanks Pete, I may switch that exhaust system over to my red '76 for the VYR.
    Wulfbyte, MaxPete, Jim and 1 other person like this.
  8. Superjet
    Superjet XS650 Guru Top Contributor
    Wow lakeview it must be a pretty good exhaust to switch to your red bike for the rally! JC
  9. NashGTI
    NashGTI XS650 Addict
    Thursday I cleaned the bike for the first time in a long time and then touched up the spots around the bike where the black was either flaking or rubbed off. Then this morning I put on the header wrap that showed up Friday and then took nicer pictures of it than I've ever taken.
    I love that picture, I'm thinking that's going to end up poster size on my wall somewhere.
  10. Well, today I sold the Queen. If all goes as planned delivery will be in Stecoah next weekend, see ya there.
    john
  11. madmax-im
    madmax-im Yamaha...Go your own way... XS650.com Supporter Top Contributor
    Well dayum..thats gonna be TWO bikes being sold online via this forum and delivered to the VYR for pickup..that gotta be a FIRST!!!
    Wulfbyte and MaxPete like this.
  12. MaxPete
    Today was bike cleanup day at the Disaster Central Workshop:
    • I washed Sylvia (2007 Honda ST1300) and boy, did she need a bath after a nearly 4000 km run in six days (only 4 days of actual riding) some of which was in the rain. That thing is amazing though - not a single burp out of it and nearly 50 MPIG average.
    • I washed Lucille (1976 XS650C) and did a bunch of things in preparation for the big VYR expedition with Lakeview which starts with loading the bikes into his Chevy Express van on Tuesday evening and an early departure on Wednesday morning.
    Lucille’s tasks included: checking the lights and horn; replacing the instrument lights with LED bulbs (brighter and should last forever in contrast to the incandescent bulbs which only last me about 2 hours it seems); removing and cleaning the alternator brushes (still within spec for length and charging at 13.15 volts); removing the shift pedal and grinding open the “pinch gap” to avoid stripping the shifter shaft spline; checking and adjusting the brakes; re-torquing the cylinder head and all of the chassis bolts; adjusting the timing chain tension and valves; changing the plugs and re-coating the insides of the HT lead ends with dielectric grease; and cleaning and lubricating all of the locks and the key switch.
    The last task is to change the oil and filters and check and clean the air filters, but it started to rain before my test ride so I couldn’t warm up the engine. Thus, those little tasks will wait until tomorrow, along with packing.
    I also did a few things on the ‘78E including checking over the tank that Gordon in NC generously sent me. It’s a good thing he did because my suspicions were confirmed this week that the original tank that Robin had for this bike is almost totally rotted out in the entire tunnel area. Every time the welder tried to braze it - more holes would open up - so that one is a loss.
    The business of opening up the “pinch gap” on your shift pedal is important folks, as was pointed out a week or two ago by, I think Gary, 5Twins or TwoMany (apologies if I got that wrong - I just don’t recall).
    Basically, you should give your shift pedal a little wiggle to see if it can move relative to the shifter shaft on which is mounted. If it is loose, you are at-risk of stripping the splines on either the pedal or the shifter shaft. If you strip the pedal, it’s a PITA but you’ll live. However, if you strip the shaft, you will have to remove and dismantle the entire engine - including splitting the crankcase - to install a new shifter shaft. That would be a heck of a lot of expense and work - and it is totally unnecessary.
    The shift pedals on ALL THREE of my XS650s were loose when I checked them today - and so this is likely a very common defect on our XS650s. I’ve already fixed the one on my VYR bike and I will do the other two tomorrow now that I have located the proper equipment.
    All you do is remove your loose shift pedal and run a thin Dremel or die-grinder cut-off wheel through the gap where the pinch bolt clamps the pedal to secure it to the shifter shaft (remove the bolt first ...duhhhhh) to create a wider pinch gap. Then just reinstall the pedal and pinch bolt and ensure that the pedal fits tightly on the shifter shaft - and you are done. Truly, a five minute fix of a potentially serious problem.
    Cheers,
    Pete
  13. GLJ
    GLJ Never go faster than your guardian angle can fly. Top Contributor
    Pete 13.15 is a volt low. You might want to recheck that after a 20 minuet ride.
    I may be wrong but I sure the shaft can be changed without removing the engine. I agree stripping the splines is something to be avoided.
  14. MaxPete
    Hmmmm....yeah I guess but the darned thing keeps starting up on the button every time and I’m pretty sure that my volt meter is good....
    Fortunately, I’ve got one of Jim’s excellent re-wound rotors in reserve if this one pooches.
    I’ll check it though - but I’m not much of a dancer ;)
  15. JAX71224
    JAX71224 jax71224
    I have the 'Bigfoot' lever from Mike's and have that same issue......even after using a longer bolt and a nut on the bottom to lock the threads against themselves. There is still plenty of 'gap' there but loosens soon after tightening and I know the bolt is not backing off. I believe it is softer metal than could be used......
    Wulfbyte, gggGary and Jim like this.
  16. MaxPete
    Hmmmm....well, that could become a big deal JAX. If you strip that shaft, yuk.
    Wulfbyte and Jim like this.
  17. lakeview
    Improved Ignition - 10 Amp for illustrative purposes only - use a 20 Amp in this '76.
    Worked on the red VYR bike to get it ready today. Oil change, new plugs, valve and cam chain check, grease swing arm and general look over.
    It had been shutting off erratically lately; after the first time knew to take off the side cover and check the fuse. When it quit in Windsor, MaxPete reminded me that it had to be a 20 Amp fuse, but a couple weeks later it stopped in a left turn lane.
    Easy to duck walk it off to safety and simply wiggled the fuse holder, got back power and today replaced it. Found that a p o had made up a male connector with some solder and carried on. All better now.
    No it is not getting the Sportster blend exhaust for the Rally. One thing I learned when I was Harley rider is to not make any big changes before a trip. Test them around town first.
  18. lakeview
    Also replaced the shift lever with one that fits correctly on the shifter shaft. Nice solid feel to it.
    Wulfbyte, gggGary, Mailman and 2 others like this.
  19. GLJ
    Not saying it doesn't. Back in the bad old days 14.2 was what you shot for. If you you are using a battery tender and using it after rides it will keep the battery charged up.
    13.2 could cause a problem if not using a tender. Mainly you would see shorter battery life.
  20. MaxPete
    Yes - I’ve been thinking about that since the battery is now about 3-1/2 years old. I think I may bring a tender to the VYR or swap Lucille’s battery with the on in the ‘78 (it is new this year).
    Decisions...decisions....
    Wulfbyte, Mailman, Jim and 1 other person like this.
Share This Page
