Lovely work and great looking workshop.
Do you have any photos of the pull clutch?
Thank's!
Yes...it's my "mancave",small but try to use every Square meter as good as I can.
Have a few photos,I will try to explain how I did it.
Made a big hole centered exactly on the gearbox axle. (put the cases on the mill,bolted it to the table,centered the mill on the bearing hole,and bolted the cover on the cases...then made the hole.)
Made a new "plate" in the lathe,with hole for pull-shaft and a seal.(made a small "edge" on the plate,so it lay flat on the cover that also have a flat Surface milled on the outside,also a couple of millimeters more room for the extra clutchplates)
Welded it together.
Modifyed a mechanism from a Suzuki GT750 3-cyl twostroke.(have a couple of such engines laying,that's why I used just that one)
Made a pull-rod in the lathe with a axial needle bearing.
Also did I plug the hole in the gearbox shaft ,the oil pumps from the other side,and without a plug I suspect the massive oilflow will "overflow" the inside of the clutch,and also loose pressure to other parts of the Engine.
Made a small bleedhole in both ends,some small amount of oilpressure is needed to lubricate the gears on the shaft,and also a small amount of oil are needed to lubricate the new needle bearing and cool the clutchplates….but that is only my belive,no "science" behind that,only my thoughts….
That's basically how I did it,lots and lots of measuring,but feels ok and Think it will work nice,but time will tell if it does….have to try to find out.
Anders
