1. Dismiss Notice
    Dismiss Notice
xs650 scrambler build
Discussion in 'The Garage' started by sean colleary, Mar 10, 2018.
  1. sean colleary
    sean colleary XS650 Addict
    ps the right plug is kind of dry but it has that carbon all around it
  2. sean colleary
    So did a compression test today
    FB679021-6C41-4CB8-B367-58CB880BDAAD.jpeg Left head
    C289A107-A59C-418C-83C8-CED4ADB8EE92.jpeg Right head
    I did this with a cheap auto zone compression tester so I don’t know how accurate it actually is this is after I tighten down the head it was way off per Cylinder before I did this .... its about 110 on bolth what yall think ps The big crown Nuts on the head were all basically just hand tight
    Jim likes this.
  3. sean colleary
    Jim likes this.
  4. TwoManyXS1Bs
    Well, it'll run like that. See if it changes over time...
    sean colleary and Jim like this.
  5. sean colleary
    Thanks dude !
    TwoManyXS1Bs likes this.
  6. sean colleary
    well carb is mostly sorted out when down 2 jet sizes on the main from a 135 it is popping on decal so i have some cleaning to do i think but shes coming together now im waiting on a seat and other miscellaneous stuff to come in the mail .... ps my room mate dropped a ladder on my tank a week ago so now its dented to all hell ... o well its going to be taking a bunch of dirt naps in the future so lol
    my xs 4:7:18.jpg
    Jim likes this.
  7. CoconutPete
    CoconutPete 1979 XS650 Special
    Looking good! Getting there. Thanks for mentioning the seat. I was going to make a "does not compute" comment lol.
    Are the risers off another bike? They look high.
    sean colleary likes this.
  8. sean colleary
    Lol ya they are off of a dirtbike lol my old ones were trashed ... o the seat im getting is from counterbalance cycles 54E9B5C3-A5BC-408E-81CB-9072F9D14823.jpeg
  9. sean colleary
    I actually have a rilly dumb question i cant actually figure out how the seat and the tank mount on that rubber bumper on the frame
  10. sean colleary
  11. fredintoon
    Hi sean,
    "there are no dumb questions"
    The stock tank has rubber nubbins inside the tunnel at the front that slide into the tank mount ears on the frame and the back of the tank has a lug that bolts down onto the frame. Drop on, push-wiggle forward, push down & insert bolt.
    The pre-'80 stock seat is hinged on the right-hand side and swings down to a latch on the left. Some or perhaps all of the seat's mounting hardware seems to be missing on your photo.
    [edit] Looking at earlier photos in this string, seems the dreaded PO didn't stop at removing the seat mount hardware, he also removed the hardware mountings. Lucky you still have the gas tank mounts, eh? BTW if your "friendly fire" damaged tank is a "Standard" (filler cap in center)
    the smaller "Special" tank (filler cap offset) drops straight on and is perhaps more suitable for a scrambler. [end edit]
  12. CoconutPete
    I have that seat. I think you'll love it.
  13. sean colleary
    How did ya mount the front of the seat by the tank ?
  14. CoconutPete
    You don't have to.
    It has an "L" shaped piece of steel that comes down in the front. You just slide it under the cross brace that the tank bolts to.
    You only need to fabricate a mount for the rear. I just used a piece of 1.5 or 2" wide steel from home depot that I cut to size, drilled 2 holes in and had a local shop weld up. See post # 6 in my build thread if you want to see a pic.
    http://www.xs650.com/threads/miesha-build-thread.48166/
  15. sean colleary
    O hell ya thanks dude !
  16. sean colleary
    Ug so im having a hard time with tuning this thing
  17. sean colleary
    well i leard how to work with points today not that hard at all and the bike runs absolutely amazing now im so stoked got some knobby on her now and liking the way shes turing out good
    robinc likes this.
  18. sean colleary
    got my seat today i love this thing it ties the bike together
    Jim likes this.
  19. CoconutPete
    That seat and those tires made all the difference in the world looks-wise. Well done!
    Jim and sean colleary like this.
Share This Page
