1. Dismiss Notice
    Dismiss Notice
Ywain
Discussion in 'The Garage' started by gggGary, Sep 10, 2019.
  1. Machine
    Machine Race the wind Top Contributor
    Barbaroonians sure are tricky fellows
  2. gggGary
    No, I hadn't come to that solution for this triple 'til after we all started bandying around ideas! Remember my first plan was removing the bearing to add a shim... You all helped! Thanks. Forks are on (for) now, more decisions to come. :umm:
    You may not know it, but I tend to collect a few things :laughing:... So I'm trying to (mostly) build this using what's "round" already.
    TwoManyXS1Bs, Wulfbyte, Jim and 5 others like this.
  3. Machine
    V twin ? :umm: ?
    Gator xs2, Jim and gggGary like this.
  4. Mailman
    You think we’re going to see a Moto Guzzi engine stuffed in there? :laughing:
    Wulfbyte, gggGary, Superjet and 4 others like this.
  5. Machine
  6. MaxPete
    MaxPete Lucille, Betty & Demi - I suggest but THEY decide. XS650.com Supporter Top Contributor
  7. aldo5468
    aldo5468 Redleg XS650.com Supporter
    Like our beloved 650 twins, Virago motors are near bullet-proof. Yamaha used them in 1100 Roadstars after Viragos went out of production. Unlike Harleys, they used twin carbs, which were not easy to remove from their nesting spot in the 75 degree vee between the cylinders - for awhile, until I learned the tricks, I thought they had to pulled out through the exhaust pipes LOL. The carbs used main jets one size apart, so you could up-jet both carbs by buying only one new jet.
    MaxPete, Wulfbyte, Jim and 1 other person like this.
  8. Superjet
    Superjet XS650 Junkie Top Contributor
    Tricky fellows hiding behind their ‘staches!!! Good machining there G. Following with interest and hope to see what will bolt on/weld or machine on next! JC
    MaxPete, Wulfbyte and Jim like this.
  9. gggGary
  10. Superjet
    Well well didnt expect that!! :smoke:
  11. Mailman
    Gary, what is that front end from? Is that a mag wheel? Is there gonna be a hydraulic clutch? Dual disc brakes ?
    The inscrutable Gary, likes to build anticipation. Makes us guess! :pimp:
    GLJ, MaxPete, Wulfbyte and 2 others like this.
  12. gggGary
    Front end from a 2005 YZF600R, features externally adjustable spring preload, rebound, and damping. Blue spot 4 piston calipers. Front wheel/fender to be determined. Maybe on the hydro clutch... Prolly going to need riser blocks for the tapered bars. This won't be your father's XS650. Just ordered a selection of SS lines for the brakes.
    madmax-im, GLJ, MaxPete and 3 others like this.
  13. Mailman
    Oooh this is fun! Thanks Gary......carry on!
    :popcorn:
    madmax-im, MaxPete, Wulfbyte and 3 others like this.
  14. GLJ
    GLJ Never go faster than your guardian angle can fly. Top Contributor
    Gary's playing chess while the rest of us are playing checkers.
    Team Junk, madmax-im, Jim and 4 others like this.
  15. MaxPete
    Don’t tell Gary...but I’ll be at the Shed of Ill Repute tonight and I will snoop around and suss out his plan and report back.
    Pete
    Wulfbyte, madmax-im, Jim and 2 others like this.
  16. gggGary
  17. 59Tebo
    59Tebo 59Tebo Top Contributor
    Franken...borg...?
    ...bike?...
    Wulfbyte, MaxPete, Jim and 3 others like this.
  18. mrtwowheel
    mrtwowheel Honda Etched On Brain Top Contributor
    I still think it's going to be a hard tail.
    Wulfbyte, MaxPete, Jim and 1 other person like this.
  19. Jim
    Nah.... Gary's a speed demon.... it's a Cafe. :whistle:
    Wulfbyte, MaxPete, madmax-im and 3 others like this.
  20. gggGary
    More like a spud demon, potatoe, potatoe.
Share This Page
