Wanted - 130/90-16 front wheel
I have a mag that size, front axle included. Wait, are you wanting to run rear tire in the front?
Here you go 130/90/16 Front 3/4 axle. I also used these on the rear
Like I said before this wheel can go onto a xs650 but you have to make changes. I don't know of a 16 wheel with a axle the same as a XS650. This wheel is a 3/4" axle and can be put onto a DNA SPRINGER or a HARLEY front like a FXR or SPORTSTER and all three DNA FXR SPORTSTER have to be modified to fit the XS650 neck. I have done all three and used the front 16" and rear 16" on a XS650 build that was a hard tail 3/4 axle plate in rear and used a older FXR front and worked great and looked good. Also was able to use stock FXR brake and mater cylinder on front and used Harley master cylinder on rear.
THIS IS WORK but can be done. I think the stock front axle on a XS650 is 17mm and rear is 20mm. Someone correct me if I am wrong.
Any changes to a bike like this takes time and experience.
Here are some pictures of bikes I built with 3/4 axle
GOOD LUCK on your build
Rich
