1979-1983 Exhaust Pipes/Mufflers
JonW
Troop
XS650.com Supporter
Barre, Vermont
Are the pipes and mufflers for these model years able to be separated ( mufflers slip onto exhaust pipes), or are they all a one piece unit?
I ask, because I want a set of header/exhaust pipes in that year range but I do not need the mufflers and associated cross-over tube.
There is a process for which I am not proud of revealing where by a 1/2 - 3/4 inch rod is inserted into the flow restricter (muffler) and said rod is struck repeatedly with a heavy mallet. The offending obstruction being displaced, the end result being a reduction of flow restriction through the restrictive device.
Yes, I banged the fu$% out of it until the welds let go...
I know for sure the '80-'83 are all one piece. Pretty sure the '79 is also.
All of the Special exhausts are one piece from ‘78 to ‘83. It’s been more than 10 years, but I did separate a set of Special exhausts mufflers from headers. It involves cutting the welds and removing layers. I don’t remember all the details, but it can be dismantled in the fashion it went together.
https://www.xs650.com/threads/cutting-stock-exhaust.48950/
If you cut off the muffler the head pipes need to have some sort of spacer inserted between the inner and outer pipes where the muffler was welded on, there's a standard auto tailpipe adapter that does the job.
Pics have dissappeared; https://www.xs650.com/threads/xs-pe...s-on-stock-special-headers.36716/#post-369813
https://shop.advanceautoparts.com/p...-adapter-1-1-2-id-x-1-3-8-od-548520/5600308-P
548520 1.5 x 1.75 in. Tail Pipe Reducer Adapter​
the 548520 is a standardized exhaust part #
