THAT WAS CLOSE ONE (NEWBIE ALERT!!!!):
receiving the tank back from paint, the first thing i did was install it. this is of course after making sure all the wires, fuses, and misc pieces were connected properly. i still have to make he connections for the switches (more on this later) which are holding up the installation of the throttle but other than that im good to go.
with the tank on, the bike came off the rack to get a feel for it. its awesome. the clutch is a little tight and the kick was acting strange....turns out the kick wasn't moving anything at all. i suddenly panicked! why was it working and now its not???
the bike went back on the rack and the right side cover off....checking things out, it looked like the clutch was slipping.
clutch apart- everything is together correctly... grrr...what have i done since putting together this motor.....
then it struck me like thunder. the tight clutch cable?!?!?! mother f-er its so tight. i wonder if its engaging the clutch now allowing the kick starter to do its thing.
entire right side of the motor re-assembled, clutch cable removed- kick works perfectly, clutch works perfectly.
with all that, i got a quick lesson in why a clutch needs adjusting
heres a link on how to do so
http://www.xs650.com/forum/showthread.php?t=7993
the clutch now adjusted, it feels good, the kick works perfectly and everything is moving
i just need those switches to arrive so i can get this bike on the road!
