I'm familiar with both the points gapping and timing procedure, that's NOT what this thread is about.
I installed new points, set the gaps to 0.016, then set the timing on my bike about 3,000 miles ago. My points gap is now 0.011. The bike runs and starts great, but I'm going to re-gap them to 0.016. Checking with a light, my timing is dead on.
In the past, I have just loosened the screw (screws # 1 and 2 in the below diagram)securing the side of the points that gets adjusted, widened the gap, checked with feeler gauge, and tightened them back down. Then went riding. My timing didn't seem to change. I did NOT loosen the screws for, or move, the large backing plate or the half backing plate that set the timing.
As with pretty much every vehicle with points that I have owned, cars, Harleys, dirt bikes, etc, this is the procedure. The points gap can be set WITHOUT changing the timing.
I borrowed this diagram from a forum member... thanks!
I have recently read on this forum, in several places, that people say you can not adjust xs650 points gap without changing the timing though. Is this true, and I have just gotten lucky in the past?
I usually loosen screws #1 and 2 in the above diagram, set the gap to 0.016, then tighten them down. My timing does not seem to change. Is this just luck or is it how its supposed to work? (I know my timing dead on to begin with, and I check it after to confirm)
EDIT FOR CLARIFICATION: The stationary points (the ones that get adjusted to set gap) should NOT have anything to do with the timing. Timing is set based on when the moving points start to open, and the moving points are attached to the large backing plate. All the stationary points do is sit there, and contact the moving points when they close.... so conceptually I do not understand how adjusting the points gap on a properly timed engine will change the timing... and that is my question. Thanks.
