littlebill31
Smells of Raw Fuel
21mm with the gasket is fine. And you measured these just when the float begins to touch the float needle, but not pushing down on it, correct?
The 145 is the main. (which is what I use because I am at sea level). Absolutely, positively no 2 bikes are the same.
The main has nothing to do with idle. The pilot jet is under the rubber plug, which controls idle to 1/4 throttle.
Don't worry about the air jet right now.
