1979cafexs
So after figuring out that the reason that the motor was running rough, which was only my exhaust valves not having enough clearance and after i adjusted all the valves she was running fantastic. when i was on a long ride with here making sure that the adjustments were all it needed the motor started to misfire an absurd amount and then soon died on me. i took the battery out and went home, recharged it, put it back in the bike and it ran fine and i took it home. this problem keeps happening though, ill charge the battery(which is only a month old) over night then put it back in, ride all day then the battery seems to loose its charge again. from what the previous owner told me when i bought the bike is that the stator had been replaced about 2 months before i bought it. I assume my problem has something to to with the charging system but im not really sure were to start, any advice or if someone has had a similar problem with a solution would be a huge help to me, thank you
-julius
-julius
