Sounds like the shop you used did a fine job; you should feel the difference! Hope you had them tack weld the pins, the flywheels have a nasty tendency to walk, especially after the crank has been taken apart and rebuilt. Just out of curiosity, where did you find the .0015" spec? In the 78-83 factory manual, Mama Yama gave herself up to .002" of runout, and many if not most untouched cranks won't hit that easy mark.
Gotcha. no welds. But I am Picking up my cam next week and ill take it with and see what he says. Thanks Grizld.Talking about the rod big end pins that go through each flywheel pair.
Curious Grizld, did you tack both sides of the pins (inside and out)? or was one tack sufficient.Gotcha. no welds. But I am Picking up my cam next week and ill take it with and see what he says. Thanks Grizld.
So, unfortunately $350.00 too late im guessing. Hate like hell to tear it down again ($700.00). Is it really that common a problem? Again unfortunate but the rebuild is for the original casing. I'm currently running a top notch second engine in the bike with lots of life but was really wanting to bring it back to total; stock.An article about crankshaft rebuilding and welding from Hugh’s Handbuilt,
https://www.hughshandbuilt.com/2011/03/15/failed-cranks-properly-build-weld-xs650-crank/
Shouldn't need to. The bearings should go on and off by hand. In fact, some people leave the bearings off because it makes it a tad easier to get the chain around the cam. After the chains fastened, lift each end and slide the bearings in place.press the four bearings onto the cam shaft this week
No need to press. The bearings should be a slip fit.Really regret not posting prior to the crank rebuild. An expensive oversight now that it appears I’m going to need to have it pulled apart again to weld the pins and do it right.
My shop is also going to press the four bearings onto the cam shaft this week - anything I should know before I blow another chunk of change?
Yes, OE camshaft bearings are a slip fit. But I bought a set of camshaft bearings from Yamaha a few years back that would have required a press, and no, a tap fit with a piece of pipe against the inside race would not have been sufficient. I stashed 'em and installed some good used OE bearings instead. Don't know what the deal is with those tight holes, the new stuff and the old stuff are both Koyo and have the same size code markings.
