OK ....
today I cut the hose extra long for use on the carb syncronizer....
started and warmed the bike up....
killed it, took off the seat and tank bolt and wedged a screw driver under the tank so I could get my hand in there on the left side to adjust the sync of the 2 carbs.
... hooked up the 2 hoses and started the bike the oil imediately started climbing on one side slowly......
i got in there and turned the adjustment screw a tiny amount and it started falling..... I let it idle a bit to see how far it would fall
turns out it only fell about 3 inches from over half way up the stick.... so I turned the screw a tiny bit more and it dropped again....
a bit more and the oil was level across i let it idle a bit and then goosed it a few times to make sure everything was seated good
it changed the reading a bit it went down too far, so I turned the screw in the oppisit direction and got it level again.....
and then went past it and back to try to get the tension off the spring .... that did the trick... it sat at level accross after a few times giving it the throttle...... so I called it good and turned it off and pit it all back together.....
.... the neet part was the sensitivity of the Carb Scync'er..... I am guessing at about 1/16" on the screw driver blade's tip in distance and it was in and out of adjustment..... 1/32" adjustments were needed to get it spot on.....
to say it works good is an understatement ! it's far more sensitive than my Uni-syn. and it works very well indeed. but this home made one is fantastic ! Thank you 2M your design works fantastically !
I recomend it far and above store bought ones ( as they were lucky to be as sensitive as my Uni-Syn , and this puts my Uni-Syn to shame ...... here is a pic of the completed Carb Sync'er .....
YOU NEED ONE OF THESE !!!!!!
total cost about $6.00 for the hose 3/16 Vynal hose at the hardware store
scrap board....
1" PVC pipe (scrap in the back yard) ( 2-6" pieces I think)
4#1" PVC Caps ( I didn't have them so I jerry rigged PVC caps of my own and welded them on with a soldering iron.)
4# 1" pices of 1/4" copper tubing ( scrap in the shop)
left over Shoe-Goo from walmart to seal up the resivours air tight.
it Works great fella's !
thanks again 2M !
Bob.........
