kungfutoast
Looks like I found my issue. I ran a bench test on the stator and my readings are out of range. Below are the test results next to the factory standards supplied with the stator unit. I guess I need to email Hugh.
Stator readings:
Source coil: green to red - Tested = 12.8 ohms / Should Read = 22ohms
Charging coil: yellow to yellow - Tested = .4 ohms / Should Read = .7 - 1.0 ohms
Pickup coil:
White/green to white/red: Tested = 126.7 ohms / Should Read = 115 ohms
Stator readings:
Pickup coil:
