bigstick1973
So I picked up a set of wheels off ebay. the clear coat was pealing off so I started off using some oven cleaner to try to remove it. It kinda worked but turned some areas black. I then tried a can of paint striper witch I sprayed it on thick and let set for about 15 mins. it seemed to work without turning black. it didn't remove the clear coat completely but did a good enough job to use a green scotch bright to rub off the rest of the clear coat. I then started with 220 grit then 400 then 600. wet sanded with a bucket of water with dawn dish soap. then used 0000 steel wool. took me about 3 hours. there not perfect and will still need new spokes. but sure do look alot better.
