I'm in the process of doing it right now, got the right-hand one done and back on the bike; also to get front running lights at the same time, I'm replacing the original single-filament sockets with dual-element Virago front sockets that fit right into the cavities in the 650 turn signals. I did not use heli-coils; just used a 6.8mm tap drill and 8mm x 1.25 taper tap to thread the shortened turn signal stubs to take the threaded rod. I drilled out the threaded rods to 4.2mm (could also use 11/64" drill) so I could get at least two wires through them. Had to remove the black ground wire from the Virago sockets - no way to drill out the rods enough to fit three wires - am just using the original 650 grounds inside the headlight bucket with the large ring terminals that fit over the threaded rod. Had some trouble getting a good ground through the threaded rod; finally just wrapped a short strand of copper wire around the threaded rod right where it enters the housing and twisted the ends together to make a tail about 1/4" long. The tail tightens up against the new cut face of the housing when you install it and provides a good ground - invisible when all tightened up.
