nhridah
so this is my first post so please go easy, but tell me if my etiquette is lacking. Anyways, ive got a 78 hardtailed bobber and the tail light has become my arch enemy. when i first got the bike it had a trailer style round light on there and it would constantly blow the bulbs so i researched and went with led and that fixed that. good. then i went through 3 more lights losing the covers rom vibrations or sometimes the entire light itself. its happened so often thats hows everyone in my riding circle knows me now. so i finally got a metal trailer light nylon screws, loctite, lock washers hooray all was fixed for a while. last ride was around christmas and i look down entire side mount plate light everything laying there dragging by the wires. the mount cracked at the weld. im assuming from vibrations. so ive now bought a new mount new light did all my other tricks to make sure this thing is going to stay on, get it all together proud of myself now, beating my chest going to turn it all on and bask in the red glow glory; i thought. turn it on and now nothing. i know my story is going on long enough here so ill just say a day and a half of redoing solder joints rewiring trying new bulbs all led me to the conclusion i had been beaten. so i got drunk and pouted. then it came to me why not touch a wire the the liht housing and then to the frame like i had done on my olld tractor and voila it worked!!!!
so now to my question.... i bought a fancy new side mount plate light bracket and its powdercoated, im assuming this is why im getting no ground. if i grind off the powdercoat at the connecting points will that fix it or should i run a cheater wire from the light to the frame?
many thanks in advance and as i said its my first post so i want to take as second and thank you all for answering many questions for me in other threads, this place has been a wealth of knowledge for me
