69mach351
Resident Newbie
Good morning. I have an '80 Special II and I am wanting to eliminate the electronics from the handlebars (leaving the throttle, brake lever, MC, I am assuming the brake light switch, and clutch - I will be getting a new lever set for this). One thing I have been trying to figure out, is how to run the throttle cable without the electronic box covering it up.
Would a set-up like this work? The first is one I like, but not in stock. The second is in stock.
http://www.monstercraftsman.com/7-8-throttle-assembly-with-vintage-style-grips-black/
http://www.ebay.com/itm/NOS-Vintage...ini-Bike-/291090616230?_trksid=p2054897.l4275
I will likely be eliminating turn signals. I will probably keep the start button and relocate it. My kill switch is froze solid on "run" so I a not sure if I need that or I should just continue to use the key.
