For Sale - Engine Part Out (447)
South Carolina
650badger
South Carolina
I went into this enthusiastically, but it seems I bit off more than I could chew. That being said, I wouldn't want my efforts to go entirely to waste. I wanted to put a lot into this project, so I acquired a few performance parts. They were meant for 1983 model, and include:
-Hot cam from WebCam racing cams. 359a regrind. ($250) SOLD
Good for mid and upper end performance.
-Cylinder head and rocker cover. ($500) SOLD
Vapor blasted to a clean finish, ported to 36mm and comes with
new Kibblewhite valves with titanium retainers and performance spring kit.
-Rebuilt crankshaft from Gary Hoos. ($1,000)
Welded pins. Comes with Carrillo con rods.
-Valve covers from analog motors. ($200)
-Shell racing cam covers. ($75) SOLD
-Vape (formally Powerdynamo) ignition system with advance CDI. ($550) SOLD
Alternative to the HHB PMA Charing & CDI Ignition System.
-Transmission set with Xs750 internals. ($75)
Specifically the third and fifth gears and dogs. Stronger with less wear. Same gear ratio.
- Ivan Hoey High Ratio Primary Gears. ($500) SOLD
Unused and ready for installation. Even comes with instructions.
- Smedspeed sump Filter Kit. ($175)
Kit allows for the use of a regular oil filter instead of the oem sump filter strainer. Plate is made from CNC'd 6082 billet aluminum with the same dimensions as the oem plate. Comes with an unused filter.
This post is to gauge interest in specific parts. Prices are as is, but will entertain reasonable offers. I'd like to make back at least some of what I invested. Worst that can be said is no. If anyone is interested in the full assembled engine, it will take some time and effort, so the final price will reflect that. I have other stock and aftermarket components, but would need to clear through them. Those can be requested as well. Sad to see this all go, but got other priorities. My loss, your gain.
